ARC Raiders Shotgun Choke 2 vs 3 Comparison Guide
Ontem, 04:29
In ARC Raiders, choosing between Shotgun Choke II and Shotgun Choke III comes down to balancing maximum effective range against how frequently you want to repair your weapon. For raiders deploying into high-threat zones, understanding the hidden mathematical trade-offs between these two muzzles can mean the difference between a successful extraction and losing your entire loadout.
Quick Stat Comparison
On paper, the progression from Tier 2 to Tier 3 seems straightforward, but the introduction of negative performance modifiers changes the economic equation significantly.
Attachment Stat Shotgun Choke II Shotgun Choke III
Rarity Uncommon (Green) Rare (Blue)
Base Dispersion Reduction -20% Spread (Tighter pellet spread) -30% Spread (Tightest pellet spread)
Durability Burn Rate 0% (Standard weapon degradation) +20% Burn Penalty (Weapon breaks faster)
Crafting Base Cost Cheap / Common components 2x Mod Components, 8x Wires
The Case for Shotgun Choke III
Extended Lethality: The extra 10% dispersion reduction narrows your pellet spread drastically. When analyzing raw pellet groups at a distance of 15 meters, Choke III tightens the impact radius by nearly a third compared to a stock muzzle. This allows high-tier shotguns like the Il Toro or Vulcano to land all of their pellets directly onto a target's critical weak points, achieving consistent 2-shot kills from near-medium range where unmodded shotguns would merely deal chip damage.
Mandatory for Meta PvP: For high-stakes extraction runs, optimized community loadouts consider Choke III mandatory. It turns your shotgun into a mid-range "sniping" powerhouse that stops human players from escaping or resetting. If your playstyle revolves around aggressive, fast-paced breach actions, the tighter choke allows you to safely engage targets out to 20 meters without suffering severe damage fall-off due to stray pellets missing the silhouette.
Market Acquisition Insight: Finding the blueprint naturally can require dozens of risky runs into residential containers or storm caches. Because of this artificial scarcity, many active raiders choose to bypass the grind entirely. If you want to check community feedback before investing your hard-earned trade capital on third-party trading hubs, looking up a comprehensive U4N platform or reading a trusted arc raiders blueprints shop review can help ensure you secure your combat mods safely and efficiently without overpaying.
Weapon Longevity & Economy: Because Choke III adds a harsh +20% durability burn rate penalty, your weapon will degrade significantly faster per raid. For example, a standard 100-durability shotgun using Choke III can drop down to critical repair thresholds after only 4 to 5 intense firefights, forcing you to use valuable spare parts frequently. Shotgun Choke II carries absolutely no durability penalty, meaning you spend fewer raw resources on constant gunsmith upkeep between your extraction runs.
Extreme Budget and Eco Runs: Choke II is highly accessible and remarkably cheap to craft. If you are running low-tier farming setups where you expect a high risk of losing your gear to rival squads, Choke II provides roughly 80% of the effective combat benefit of its tier-three counterpart for a mere fraction of the long-term maintenance overhead. It strikes the perfect sweet spot for sustainable, solo scavenging.
The Tactical Verdict
Equip Shotgun Choke III if you are fully kitting out a high-tier Vulcano IV or Il Toro IV for serious PvP encounters where maximizing raw damage-per-shot at range takes absolute priority over weapon durability and long-term operating costs.
Stick to Shotgun Choke II if you are running eco/farming builds, want to minimize gunsmith repair bills, or haven't yet farmed the elusive Tier 3 blueprint from high-tier danger zones.
  A Guide to the Addictive World of Slope Hicad19 0 5 Ontem 22:33
Última Resposta: Hicad19
  RSVSR D2R Runes Guide for Beginners d2itemsrsvsr 3 2.677 Ontem 22:32
  How to Farm Surge Coil Fast in Arc Raiders lOGaNKInG708 0 6 Ontem 03:26
Última Resposta: lOGaNKInG708
  College Football 27 Coins: A Practical Buying Guide FrostPhoenix 0 11 11/06/2026 05:15
Última Resposta: FrostPhoenix
  Ragdoll Archers Game Guide & Gameplay Tips invisibles 0 26 08/06/2026 23:24
Última Resposta: invisibles
  U4GM: How to Find and Use ARC Motion Cores in ARC Raiders Blustery 0 46 02/06/2026 22:47
Última Resposta: Blustery
  Re: FC 26 Future Stars Guide: How to Get the Best Players and Maximize Rewards makabaka 2 236 27/05/2026 23:05
  Forza Horizon 6 Single-Player Convoy Guide FrostPhoenix 0 136 09/05/2026 02:54
  EZG.com Review 2026: Best Game Services for Monopoly GO, ARC Raiders, TBC & GOP3 makabaka 0 236 08/02/2026 23:21
Última Resposta: makabaka
  FC 26 Future Stars Guide: How to Get the Best Players and Maximize Rewards makabaka 0 197 08/02/2026 22:45
