U4GM: How to Find and Use ARC Motion Cores in ARC Raiders
02/06/2026, 22:47
ARC Motion Core is one of those materials you don't think much about at first, then suddenly you're short on it and stuck staring at a recipe you really wanted to finish. It sits right in the middle of ARC Raiders' crafting loop, especially once you start chasing stronger gear, better components, and useful ARC Raiders BluePrints that push your loadout past the basic scavenger stage.
Quick route through this guide
What ARC Motion Core is used for.
Where players usually find it.
How crafting and recycling work.
When to spend it, and when to hold it.
You'll usually get ARC Motion Core from ARC enemies, tougher encounters, and areas where the machines are more active. It isn't the same as loose scrap or common junk. Treat it more like a bridge material. You use it to move from simple survival crafting into more serious upgrades. If you're farming low-risk zones all evening, don't be shocked if your stash barely grows. The better drops tend to come when the fight is a bit uglier.
Where it fits in your resource loop
The neat part is that ARC Motion Core isn't only a drop. You can make it at Refiner II by spending 8 ARC Alloy, which gives you a reliable path when luck isn't helping. That said, don't burn through Alloy without thinking. A lot of players do this early, then realise another recipe needed the Alloy instead. It's better to check your next two or three crafting goals before converting everything in one go.
Recycling is handy, but it can also become a bad habit. If you keep breaking Motion Cores down every time you need Alloy, you'll slow your progress toward advanced parts. I'd only recycle when you've got a clear reason, like finishing a weapon upgrade right now or fixing a shortage before a planned craft. Otherwise, let them sit in storage. They'll get used sooner than you think.
Farming habits that actually help
If you want more Motion Cores, go after stronger ARC units rather than wandering safe routes and hoping for the best. Bring gear you trust, not the kit you're half-testing. High-risk zones can pay well, but they punish sloppy runs. It also helps to stack goals. For example, take missions that send you into ARC-heavy areas, loot while you're there, then leave before greed gets you killed. Simple, but it works.
Why you should keep a reserve
ARC Motion Core becomes more important as your crafting list gets wider. Weapons, advanced components, and specialist equipment can all lean on materials like this, so keeping a small reserve saves a lot of hassle later. If you're planning bigger upgrades or comparing market options such as ARC Raiders Materials for sale while managing your own stash, use Motion Cores with a plan instead of spending them the moment they appear.
  How to Use Security Breach in ARC Raiders with U4N Guidance ParkerBlair 0 79 23/07/2026 06:35
Última Resposta: ParkerBlair
  Câmbio i Motion Pedro Almeida 50 127.996 13/07/2026 22:27
  Arc Raiders Venator Fire Rate Nerf: Upgrade Scaling Changes and Cadence Mechanics lOGaNKInG708 0 164 17/06/2026 05:09
Última Resposta: lOGaNKInG708
  Arc Raiders Trailblazer Reddit Breakdown: Meta Changes, Nerfs & Best Blueprint lOGaNKInG708 0 154 17/06/2026 04:23
  ARC Raiders Shotgun Choke 2 vs 3 Comparison Guide lOGaNKInG708 0 156 13/06/2026 04:29
  How to Farm Surge Coil Fast in Arc Raiders lOGaNKInG708 0 150 13/06/2026 03:26
  U4GM on Where Diablo 4 Seasonal Progress Moves Andrew736 0 147 06/06/2026 05:57
Última Resposta: Andrew736
  Why GTA 5 Players Trust U4GM for Mission Prep Andrew736 0 133 06/06/2026 05:54
  Câmbio I-motion é normal? rmalonso 16 28.116 04/06/2026 09:54
  Where to Start poe2 Runes of Aldur Challenges | U4GM Hartmann846 0 165 03/06/2026 05:41
Última Resposta: Hartmann846
