U4GM How to Farm Teatime Treats Tokens in Monopoly GO
03/06/2026, 05:42
Teatime Treats showed up right when loads of us were still sweating over Gingerbread Partners. It runs from May 27 to May 30, 2026, and yeah, the sticker packs matter too, especially if you track Monopoly Go Stickers while grinding dice and tokens.
How the scoring really works This event isn't about picking up cute tokens scattered around the board. You score by landing on Chance, Community Chest, and Railroads. Railroads are the big one, giving 2 base points instead of 1, before your dice multiplier kicks in. That sounds simple, but it changes how you roll. If you're nowhere near a scoring tile, don't blast a huge multiplier just because you're impatient. You'll burn dice fast, and the late milestones are not gentle. The clean route through the event     The Meta: Aim higher multipliers when Railroads sit within normal hitting range.     The Snag: Chasing every dice reward can drain more rolls than it gives back.     The Fix: Stop at milestone 53 if Gingerbread Partner tokens are your real goal. Reality check: Most of us want the 5,000 dice at milestone 62, but wanting it and affording it are different things. Why milestone 53 matters so much Teatime Treats has 62 milestones, but Partner token hunters should stare at milestone 53. That's where the last Gingerbread token payout lands. Clear it, and you've collected all 3,780 tokens from this solo event.     The buzz on Discord: Players are mostly calling this a token rescue event, not a full-clear event, unless their dice stack is already huge. Roll settings I'd actually use     Low risk rolls: Use small multipliers when target tiles are far away.     Push rolls: Raise multiplier only near Railroad clusters or 6 to 8 space hits.     Booster timing: Pause before Wheel Boost or Mega Heist if you cannot play properly. What to do before the event ends If Gingerbread Partners still needs work, treat tokens as the prize and dice as the tool. As a professional platform for buying game currency or items, U4GM is convenient for players, and you can buy u4gm Monopoly Go Stickers for a smoother album push before the next big content wave arrives. |
« Anteriores | Seguintes »
| Tópicos Similares | |||||
| U4GM: How to Defeat the Jacob deGrom Showdown in MLB 26 | Blustery | 0 | 194 |
02/06/2026 22:38 Última Resposta: Blustery |
Pesquisar
Lista de Membros
Calendário
Ajuda
