U4GM: How to Defeat the Jacob deGrom Showdown in MLB 26
02/06/2026, 22:38 (Resposta editada pela última vez em: 02/06/2026 22:40 por Blustery.)
Taking on the newest Diamond Dynasty Showdown feels less like a quick mode and more like a stress test for your whole approach at the plate. You can't just draft a few big names and hope the ball flies. The run starts in the draft room, where grabbing a bat like 90 overall Juan Soto changes everything. His contact and power against right-handed pitching give you a real answer against elite arms, and smart roster building matters just as much as stacking MLB 26 Stubs for team upgrades. An 88 overall squad with steady contact, usable power, and a few left-handed bats gives you a fighting chance once the pressure ramps up.
What the draft needs to cover
You'll notice pretty quickly that this isn't the place for a cute lineup. You need hitters who can punish fastballs, stay alive on sliders, and avoid weak rollover contact. Left-handed bats are huge here, especially when the last wall is Milestone Jacob deGrom. Corey Seager and Brandon Nimmo fit that job well because they don't feel lost against high velocity. The bench matters too. A late pinch-hit spot can save a run, and one run is often the whole difference in Showdown.
Core priorities before the boss fight
Draft at least two strong left-handed power bats for deGrom.
Take contact perks that help with two-strike counts and runners on base.
Avoid chasing low breaking balls early in the count.
Use early mini-challenges to build confidence, not just runs.
Keep your best hitters near the top so they get extra chances.
Why deGrom changes the whole pace
The last matchup is rough because it's played on Hall of Fame difficulty, and the scoreboard already looks ugly. You're down 34 to 48 with 27 outs to work with. That sounds like plenty until deGrom starts painting 101 mph fastballs and snapping sliders just off the zone. The first goal isn't to hit five homers in a row. It's to stop giving away outs. A perfect-perfect swing from Soto can spark the comeback, sure, but the boring at-bats matter too. Foul off pitches. Take the borderline stuff. Make him throw.
How the comeback usually happens
Once deGrom gets past 70 pitches, the game starts to feel different. Not easy, just different. His energy dips, and those perfect edges become a little less perfect. That's when line drives into the gaps turn into rallies, and the 14-run gap finally starts to shrink. Tying the game at 48 with 14 outs left sounds safe, but it isn't. Players often get excited there and start chasing. Don't. The last five outs can feel worse than the first twenty. If you keep the same approach, use your lefties well, and stay calm through the noise, this Showdown becomes beatable. For players grinding Diamond Dynasty and managing resources like MLB The Show Stubs along the way, beating deGrom is less about luck and more about discipline when the game tries to rush you.
  U4GM How to Farm Teatime Treats Tokens in Monopoly GO Hartmann846 0 219 03/06/2026 05:42
Última Resposta: Hartmann846
