VCDS Erro - CrossUp TSI 16
Salve galera, blz?
Possuo um cabo genérico ATMega 19.6 e estou com 2 problemas.
Não estou conseguindo fazer o Auto-Detect do Auto-Scan. Vi em um tópico bem antigo lá do fórum do Ross-Tech (https://forums.ross-tech.com/showthread....he-gateway) que não era possível. Isso mudou? Para mim da esse erro "Function not supportedd by the gateway".
Segundo, quando tento acessar o "07 - Coding" da central "09. Central Eletrônica", da erro "Sorry, no coding information is available for this ecu..."
Valeu
Código:
Friday,01,November,2019,18:18:01:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com Chassis Type: 12-VW12 (6A - VW Up Brazil (2014 >)) Scan: 01 02 03 08 09 10 15 17 25 44 56 ------------------------------------------------------------------------------- Address 01: Engine (J623-CYTA) Labels:. 04E-907-309-V1.clb Part No SW: 04C 906 026 J HW: 04C 907 309 AD Component: R3 1.0l TFS H23 5361 Revision: WDH23--- Coding: 00110012230400000000 Shop #: WSC 01434 998 00000 ASAM Dataset: EV_ECM10TFS01104C906026J 001010 ROD: EV_ECM10TFS01104C906026J.rod VCID: 285F4DA753F3120FCF-807C Readiness: 0000 0000 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: None Part No SW: 1S0 614 117 T HW: 1S0 614 117 T Component: EBC 460 MABS H26 0400 Serial number: 5478551 Coding: 12DF24E32AF4105A489F240D54F80840580100 Shop #: WSC 03310 453 00205 ASAM Dataset: EV_Brake1ABSEBC460TRW 001003 ROD: EV_Brake1ABSEBC460TRW_VW12.rod VCID: 3C7781F7B76BAEAFBB-8068 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:* 34D-937-087.clb Part No SW: 34D 937 087 D HW: 34D 937 087 D Component: BFM Hp 122 0105 Coding: DFC5C10E07008F2F2D01996DB00100221117 Shop #: WSC 03310 453 00209 ASAM Dataset: EV_BCMBFMHella 003001 ROD: EV_BCMBFMHella.rod VCID: 3169A0C3602953C718-8064 Sensor For Anti Theft Alarm System: Subsystem 1 - Part No: 5Z0 947 105 E Component: DWA-Sensor 003 0008 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb Part No SW: 1SB 919 475 HW: 1Q0 919 475 Component: PARKHILFE 3K H03 0010 Revision: -------- Serial number: 32961605700208 Coding: 100002 Shop #: WSC 03310 453 00209 ASAM Dataset: EV_EPHVA14VW1200000 001008 ROD: EV_EPHVA14VW1200000.rod VCID: 09192823A8394B07F0-805C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 1SB 959 655 HW: 1SB 959 655 Component: VW10AirbagSZX H03 0006 Revision: -------- Serial number: 003MX306C542 Coding: 000000000000000000000000000000005A58 Shop #: WSC 03310 453 00209 ASAM Dataset: EV_AirbaVW10BPAVW12X 001001 ROD: EV_AirbaVW10BPAVN750_VW12.rod VCID: 0D111C33DC515727DC-8058 Crash sensor for front airbag: driver side: Serial number: 3555NRB4016557E0JPNG No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1 Part No SW: 1SB 920 860 D HW: 1SB 920 860 D Component: KOMBI H09 0209 Revision: V0H09V07 Serial number: Coding: 814A00 Shop #: WSC 03310 453 00209 ASAM Dataset: EV_KombiUDSMM9RM10 A04752 ROD: EV_KombiUDSMM9RM10_A04_VW12.rod VCID: 4385FA0BCA95D157FA-8016 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 1SB 920 860 D Component: IMMO H09 0209 Revision: V0H09V07 Serial number: Shop #: WSC 00000 000 00000 ASAM Dataset: EV_ImmoUDSMM9RM10 A01702 ROD: EV_ImmoUDSMM9RM10_VW12.rod VCID: 6ADB77AF8D7FE01F19-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb Part No SW: 1S1 909 144 P HW: 1S1 909 144 P Component: EPS_ECU H51 1702 Coding: 0001000001010000 Shop #: WSC 03310 453 00209 ASAM Dataset: EV_SteerAssisNSK 014008 ROD: EV_SteerAssisNSK_014.rod VCID: 408FF507DB83CA4FE7-8014 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 1SB 035 152 B HW: 1SB 035 152 B Component: MIBGLAM H08 0041 Revision: RA101000 Serial number: VWZ7Z2S6062865 Coding: 00000400020000 Shop #: WSC 06133 000 1048576 VCID: 387F9DE78B53828F5F-806C No fault code found. End-------------------------(Elapsed Time: 03:06)--------------------------
  Erro p2177 Lucas Torres 1 3.789 19/11/2025, 21:23
Última postagem: Blacktsi
  Alguém já teve esse erro e conseguiu resolver U030700 Leandro Silvana 3 6.722 29/12/2022, 11:59
Última postagem: joaofardin
  SWAP cambio do Golf TSI 1.0 ou 1.4 no UP TSI troyaks 1 4.519 10/10/2022, 12:26
  Falhas e Diagnósticos via VCDS AFelippe 5 14.391 21/09/2018, 11:05
Última postagem: carlosguarulhos
  1.0 TSI 105cv (up!) x 1.0 TSI 125cv (golf) Leandro_cwb 20 42.576 14/03/2018, 21:45
  Erro de consumo no computador de bordo. Ludtke 62 116.758 21/09/2016, 08:32
Última postagem: cafuzz
  Vídeo sobre Tecnologia do Motor Up! TSI (EA211 1.0l TSI) Blondsp 5 12.518 29/07/2016, 19:13
Última postagem: Blondsp
