How to Build Grow a Garden AFK Pet Combos - u4gm
03/06/2026, 00:03
Some players love active grinding, but plenty of us just want the pets to keep working while we're eating, sleeping, or doing something else. That's where AFK pet loops start to matter. If you're trying to build progress without burning through fruit, a good setup can level pets and push KG at the same time. It also helps when you're saving resources for other upgrades, trading, or checking prices on GAG Items without feeling like your account has stopped moving.
The basic Lion and Peacock loop
The simplest setup most players talk about uses a 60 KG Lion and a Peacock with a 15-second timer. Once their skills line up, they can keep triggering each other in a steady loop. It's not flashy, but it works, and that's why people still use it. You don't need toys. You don't need fruit. You just need the timing to settle in. After the loop is running, many players add an Elephant and the pet they want to train. In testing, this method pushed a pet to Age 50 in around 7 minutes and 4 seconds, which is solid for something you barely have to touch.
Adding Griffin for quicker age gains
If you want the same hands-off style but a bit more speed, the Griffin version is usually the next step. This one needs a 60 KG Lion, a 15-second Peacock, and a 60 KG Griffin. A Tiger can help get the timing right at the start, though players often remove it once the main cycle is stable. You'll notice the pace feels better pretty quickly. The Lion and Peacock keep the engine running, while the Griffin helps push levels harder. During tests, this setup reached Age 50 in about 6 minutes. That's a nice jump, especially if you're running it again and again over a long session.
The Colossal Peacock version
The strongest version is harder to build, but it's the one serious AFK players tend to chase. You'll need a Colossal Peacock with at least 140 seconds of cooldown reduction, plus a 60 KG Lion and a 60 KG Griffin. Most players get there with a Peacock around 100 KG or higher, though extra passive bonuses can help. Once it's synced, the loop keeps moving without much babysitting. The best part is the free pet slots. You can use those for the pet you're ageing, extra support, or whatever fits your plan. In testing, this setup hit Age 50 in roughly 5 minutes and 56 seconds.
Pick the setup that matches your account
Not everyone needs the most advanced loop right away. If your pets are still modest, the Lion and Peacock combo is a clean place to start. If you've already got the Griffin ready, the second setup is probably the best balance of effort and reward. The Colossal Peacock route is for players who've got the weight, the cooldown reduction, and the patience to tune it properly. While you're building toward that, it's worth keeping an eye on upgrades, trades, and Grow a Garden Items that might make the next setup easier to finish, because a stable AFK loop saves a lot of time over the long run.
  U4GM Diablo 4 Guide: Season 13 Reckoning Updates luissuraez798 0 46 03/06/2026 07:06
Última Resposta: luissuraez798
