Códigos falhas
Boa tarde, amigos,
Sou novo no fórum e novo proprietario de um up tsi 19/20. Gostei muito do carrinho. Peço desculpas se não estiver no tópico correto (mas tentei inserir da parte elétrica que são os erros de código).
Pelo que andei acompanhando, vocês entendem muito. Espero poder aprender um pouco.
Adquiri um vcds para ele e corri o scanner. Seguem códigos de falhas:
7 Faults Found:
03428 - Activation of Left Adaptive Light
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 20
Reset counter: 40
Mileage: 38192 km
Time Indication: 0
Date: 2023.08.25
Time: 18:24:27
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 23
Mileage: 38906 km
Time Indication: 0
Date: 2023.10.05
Time: 23:55:57
03429 - Activation of Right Adaptive Light
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 40
Mileage: 38192 km
Time Indication: 0
Date: 2023.08.25
Time: 18:24:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 23
Mileage: 38906 km
Time Indication: 0
Date: 2023.10.05
Time: 23:55:57
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 38184 km
Time Indication: 0
Date: 2023.08.24
Time: 00:31:18
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 38184 km
Time Indication: 0
Date: 2023.08.24
Time: 00:31:18
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 197
Mileage: 38189 km
Time Indication: 0
Date: 2023.08.25
Time: 18:16:15
1 Fault Found:
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 38184 km
Date: 2023.08.24
Time: 00:31:42
Voltage terminal 30: 12.4 V
Como não sou da área, se puderem me ajudar. Ainda, verificando a questão do óleo, recomendaram-me trocar a cada 06 meses (o que achei estranho, porque pela especificação seria 12). Além disso, no scan aparece: poor oil quality (qualidade pobre de óleo). Alguém sabe por que?
Até agora, só utilizei o scan p/ ver os erros e deixar a direção mais leve (apliquei agora, então, não testei ainda). Se tiverem boas recomendações, são bem vindas - embora eu tenha visto no tópico específico que para esse carro não tem muita opção.
Obrigado a todos antecipadamente.
  Falhas e Diagnósticos via VCDS AFelippe 5 14.320 21/09/2018, 11:05
Última postagem: carlosguarulhos
  Dicas muito interessantes para falhas cabeludas Massa 1 6.130 19/04/2018, 08:32
Última postagem: Cadu5000
  Erros e falhas com Piggyback maraccini 10 21.484 08/01/2016, 21:59
Última postagem: maraccini
