VCDS Erro - CrossUp TSI 16
05/11/2019, 22:08
Salve galera, blz?
Possuo um cabo genérico ATMega 19.6 e estou com 2 problemas.
Não estou conseguindo fazer o Auto-Detect do Auto-Scan. Vi em um tópico bem antigo lá do fórum do Ross-Tech (https://forums.ross-tech.com/showthread....he-gateway) que não era possível. Isso mudou? Para mim da esse erro "Function not supportedd by the gateway".
Segundo, quando tento acessar o "07 - Coding" da central "09. Central Eletrônica", da erro "Sorry, no coding information is available for this ecu..."
Valeu
Código:
Friday,01,November,2019,18:18:01:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Chassis Type: 12-VW12 (6A - VW Up Brazil (2014 >))
Scan: 01 02 03 08 09 10 15 17 25 44 56
Address 01: Engine (J623-CYTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 J    HW: 04C 907 309 AD
   Component: R3 1.0l TFS   H23 5361
   Revision: WDH23---
   Coding: 00110012230400000000
   Shop #: WSC 01434 998 00000
   ASAM Dataset: EV_ECM10TFS01104C906026J 001010
   ROD: EV_ECM10TFS01104C906026J.rod
   VCID: 285F4DA753F3120FCF-807C
Readiness: 0000 0000
No fault code found.
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 1S0 614 117 T    HW: 1S0 614 117 T
   Component: EBC 460 MABS  H26 0400
   Serial number: 5478551
   Coding: 12DF24E32AF4105A489F240D54F80840580100
   Shop #: WSC 03310 453 00205
   ASAM Dataset: EV_Brake1ABSEBC460TRW 001003
   ROD: EV_Brake1ABSEBC460TRW_VW12.rod
   VCID: 3C7781F7B76BAEAFBB-8068
Address 09: Cent. Elect. (J519)       Labels:* 34D-937-087.clb
   Part No SW: 34D 937 087 D    HW: 34D 937 087 D
   Component: BFM Hp        122 0105
   Coding: DFC5C10E07008F2F2D01996DB00100221117
   Shop #: WSC 03310 453 00209
   ASAM Dataset: EV_BCMBFMHella 003001
   ROD: EV_BCMBFMHella.rod
   VCID: 3169A0C3602953C718-8064
   Sensor For Anti Theft Alarm System:
   Subsystem 1 - Part No: 5Z0 947 105 E
   Component: DWA-Sensor  003 0008
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1SB 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0010
   Revision: --------    Serial number: 32961605700208
   Coding: 100002
   ASAM Dataset: EV_EPHVA14VW1200000 001008
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 09192823A8394B07F0-805C
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 1SB 959 655     HW: 1SB 959 655
   Component: VW10AirbagSZX H03 0006
   Revision: --------    Serial number: 003MX306C542
   Coding: 000000000000000000000000000000005A58
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 0D111C33DC515727DC-8058
   Crash sensor for front airbag: driver side:
   Serial number: 3555NRB4016557E0JPNG
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1SB 920 860 D    HW: 1SB 920 860 D
   Component: KOMBI         H09 0209
   Revision: V0H09V07    Serial number:
   Coding: 814A00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04752
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 4385FA0BCA95D157FA-8016
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 1SB 920 860 D
   Component: IMMO          H09 0209
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6ADB77AF8D7FE01F19-803E
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S1 909 144 P    HW: 1S1 909 144 P
   Component: EPS_ECU       H51 1702
   Coding: 0001000001010000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 408FF507DB83CA4FE7-8014
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1SB 035 152 B    HW: 1SB 035 152 B
   Component: MIBGLAM       H08 0041
   Revision: RA101000    Serial number: VWZ7Z2S6062865
   Coding: 00000400020000
   Shop #: WSC 06133 000 1048576
   VCID: 387F9DE78B53828F5F-806C
End-------------------------(Elapsed Time: 03:06)--------------------------
  Erro de consumo no computador de bordo. Ludtke 63 114.368 04/06/2026 09:27
  Erro p2177 Lucas Torres 1 3.541 19/11/2025 21:23
Última Resposta: Blacktsi
  Alguém já teve esse erro e conseguiu resolver U030700 Leandro Silvana 3 6.467 29/12/2022 11:59
Última Resposta: joaofardin
  Falhas e Diagnósticos via VCDS AFelippe 5 14.022 21/09/2018 11:05
Última Resposta: carlosguarulhos
