GTA 5 Tips on U4GM: Maximize Dealer Profits
06/06/2026, 05:59
This week in GTA Online is one of those stretches where it pays to slow down, check your map, and sell smart instead of just grinding the same old missions. Street Dealers are paying double, and that changes the maths quite a bit. If you're chasing faster progress than a fresh character can offer, GTA 5 Modded Accounts are often talked about by players who don't want to start from zero, but for anyone already running businesses, this event is a tidy earner. The big trick is simple: keep your drug stock moving, don't let supplies sit idle, and visit every dealer you can each day.
Street Dealers are worth the daily trip
There are three Street Dealers active around Los Santos and Blaine County every real-world day. They won't show up across the whole map at first, which catches some players out. Drive close enough, though, and a purple speech icon pops up on the mini-map. Once you know that, it becomes a quick route rather than a treasure hunt. The money is strong because these sales pull stock straight from your businesses, including Cocaine Lockups, Meth Labs, Weed Farms, and Acid Labs.
ProductExample Sale AmountApproximate Double-Payout Value
Cocaine1 unit$80,400
Meth2 units$16,950
Weed10 units$29,100
Acid10 units$30,500
Keep the supply side under control
The dealers are great, but they're not magic. If your businesses are empty, you've got nothing to sell. That's why supply management matters more than usual this week. Buying supplies is easy, sure, but it cuts into the profit. If you've got the patience, stealing supplies keeps margins much cleaner. Stash Houses are also a no-brainer, since one raid per day can hand you a free resupply for one owned business.
Raid a Stash House daily if you can.
Check which businesses are low before selling to dealers.
Prioritise Cocaine and Meth when stock is limited.
Use Acid stock as a steady backup earner.
Plan a route so all three dealers are handled in one run.
Solo players can make this work
You don't need a crew for this method, which is why it feels so useful. A lot of GTA Online money-making still gets messy in public lobbies, especially when deliveries are involved. Street Dealer sales are quicker and lower stress. You pull up, sell what they want, and move on. If you hit all three dealers, you can often see around $160,000 to $170,000 from each one, depending on demand and stock. Do that every day during the event and the total can push close to $4 million over the week.
Build a routine and stick with it
The best play isn't to abandon your MC businesses. It's to fold the dealers into what you're already doing. Restock, raid a Stash House, check dealer locations, then sell the highest-value products first. Some players will still look at cheap GTA 5 Accounts when they want a faster setup, but if you've already got the businesses unlocked, this event gives you a clean reason to log in daily. Keep it simple, don't waste stock, and the cash stacks up fast.
  U4GM Guide: Where to Reroll Rituals in poe2 Andrew736 0 169 06/06/2026 05:58
Última Resposta: Andrew736
  How to Master Diablo 4 Season 13 Updates with U4GM luissuraez798 0 139 03/06/2026 07:01
Última Resposta: luissuraez798
  U4GM: Diablo 4 Season 13 Unique Farming Strategies and Routes 1fuhd 0 129 20/05/2026 23:41
Última Resposta: 1fuhd
  U4GM GTA Online Motor Madness Event Continues from May 21‑27 1fuhd 0 153 20/05/2026 23:38
